Draft Analysis and Lost Edges
Draft anlalysis doesn't work. Part just turn into a white color surface. Also when zooming or using some commands lines in "Shaded with Edges" mode lost contours.
I have tried by changin drivers from NVIDIA but still not working. Even if I use certified drivers. This never heppened in previous versions. 😞
APDSU 2017
Autodesk Inventor Professional 2017
Build: 199, Release: 2017 R2
Windows 7 Ultimate SP1-64 Bit
Intel Core i7-2600, 3.4 Ghz
16 Gb RAM
Nvidia Quadro K2000
Driver: 368.39
JDMather
A am fairly certain the problem is with your install or video card/driver - but just to be sure, can you attach the file here that exhibits this behavior?
If you take the part over into the Inventor Tooling (mold) environment do you see the same behavior?
Something looks fishy at the intersection of the cylinder at the top of the part?
If you create a simple tapered box or cone in a new file do you see the same behavior?
