Double click to edit
Mgła3
Mgła3
Is there a double click to edit option? I just want to double click and bring up all the feature dimensions, I also want it to highlight the feature in the feature tree so I can find it. Again, all the things I'm used to Solidworks doing. It seems to be going from greed to blue surface and selecting the adjacent tangent surfaces, but I don't see when that would ever be relevant. Typing double click in search doesn't seem to give me any access to a setting that would change the double click action either. Opening application options doesn't help since it doesn't have a search field either, and I haven't found it there.
A.Acheson
Hi @Mgła3
I am assuming your in a part. Only the parameter window will have the feature dimensions. Not available by double click. You can right click edit to start editing and adjusting the feature. There is no setting f9r double click to my knowledge.
Regards
Alan
Mgła3
Yes, I'm in a part, but actually even in an assembly I'm use to double clicking anything and being able to see and change the feature values. Here's an assembly example of the dimensions of a cut that made the surface I clicked. Why make it difficult and have to open sketches, when you could instantly change anything from anywhere!
A.Acheson
Yes I agree it would be a logical workflow to have the options. It really is only about sequencing a bunch of button commands together. I guess it comes down to an older UI. There is a idea station here for these kind of improvements. Have a poke around there and if it's not there allready add it in. I would vote it up. I can allready sense my arm in pain navigating into the part through multiple dialogues to get to parameter window or to a sketch the time evaporates also.
Regards
Alan
SBix26
It doesn't get everything you want, but if you right click on any feature in the feature tree and select Show Dimensions, you have immediate access to all the sketch dimensions and feature dimensions that created that feature.  When finished editing, click Update to make it happen.
To find out what the feature is, select a face, then hover your cursor over the Edit Feature icon in the context toolbar.  The tooltip indicates what kind of feature you would be editing, but it also highlights the specific feature in the model browser.  Unfortunately, it does not scroll the browser; if your feature is not visible you'll have to scroll to find it.
Sam B
Inventor Pro 2024.2 | Windows 11 Home 22H2
johnsonshiue
Hi! I believe you are talking about double-clicking on geometry in the graphic window to edit the feature, right? If yes, it is already available. You need to change the Select Filter. The default is Face and Edge Select. Change it to Feature Select. You will be able to select the geometry as the feature and double-click to edit. Otherwise, double-clicking on the feature node in the browser to edit.
Many thanks!
Software Test Engineer
Mgła3
Thank you.
The full answer is to Shift+Right Mouse Click, change to Feature Priority, and then double click on a feature will bring up all the dimensions and dialog box as expected.
Appreciate it!
