Donload Inventor 2015
Hello
I am trying to find the path for the download of the Inventor 2015. On the Autodesk homepage are only 2016 or later versions available.
Felipe
mcgyvr
@Anonymous wrote:
Hello
Felipe
Why do you need the old version?
Typically Autodesk only supports/allows downloads for the past 3 releases or so..
If you have a student license I don't think it will allow 2015 be licensed anymore either..
(The response from Ava (Autodesk Virtual Assistant))
 Per Autodesk policy, I can only provide downloads for the latest version and up to the previous 3 versions.
I have a regular Serial No for a commercial license.
It's a license that does not expire, as far as I know.
Thanks for the help
Mark.Lancaster
@Anonymous
Inventor 2015 is retired, but you can review this article for additional information.
However are you 100% sure this serial # was not used on a maintenance plan or upgraded to a newer version of Inventor?
Mark Lancaster
Hello Mark,
yes I am sure is not part of a maintenance plan.
I bought the Inventor in 2015 and I never upgraded it. The company I bought is licensed for selling Autodesk products. They called me a couple times if I wanted to upgrade for a new Inventor version with 25% discount. If it was not a licensed product they would not call me.
Thanks for the attention.
F.
mcgyvr
You likely need to contact Autodesk to see if they can provide you with a download for the older software..
Try here..
https://knowledge.autodesk.com/contact-support/downloading-my-products
