I don't want to see my hatch boundary in my print. Similar to how drawings look in Autocad when printed. The below hatches were created in my IDW within a sketch and the closest it comes to not printing is selecting a (gray) color that is close to the background, however it appears as a white line or even darker than background. (see second photo below)
Here I changed the color but it gives a watermark illusion. That is less than desirable.
Solved by blandb. Go to Solution.
Edit your sketch where you had selected the sketch boundary and set them to sketch only. See below to see if this is what you are after:
Before:
Sketch only:
After:
