Does Inventor require Excel or can I use any spreadhseet editor?
iMaJiNe_Designs
iMaJiNe_Designs
I'm using Inventor 2021, and Microsoft's Office 365 is causing me problems with other non-Autodesk products.  I'd like to ditch Office 365 and go to Libre Office or Open Office.  As long their spreadsheet programs are compatible with Excel's XLS/XLSX format; will I have a problem?
Thanks, Matt
swalton
Inventor requires a local install of MS Excel for full functionality.   I'd be wary of any of the Office 365 products that are not a full local copy of Excel.
There has been development effort to reduce the dependence on Excel but it is still required for some functions.  I don't know if the Excel requirement will ever be eliminated.
See:
https://knowledge.autodesk.com/support/inventor/troubleshooting/caas/sfdcarticles/sfdcarticles/Syste...
And
https://knowledge.autodesk.com/search-result/caas/simplecontent/content/inventor-excel-requirements....
Steve Walton
Inventor 2025
Vault Professional 2025
iMaJiNe_Designs
Thank you for the prompt reply.
After looking over the two links you provided, it appears I may get by not having Excel.  But that's a big if too.  I may just uninstall Excel and see what happens.  I can always reinstall it if need be.
I really hope Autodesk migrates away from requiring a local copy of Excel being on the system, and just require XLS/XLSX file compatability for spreadsheet related commands.
