I'm having a weird issue that just started a few days ago. After placing two projected views on a idw sheet of a 3d model(ipt) the wireframe version without color looks fine. When I turn on the color or shading, i get a hexegonal shaped radial bitmap behind the wireframe. This only happens on some drawings and not all. See the images below:
My workstation has two nVidia Quadro M4000 8GB Video Cards that are attached to four Samsung 4K 28" monitors. I have two monitors per card. Using Driver version 411.95. Any help be greatly appreciated.
Solved by sgwilliams. Go to Solution.
Right click on the view.
Do you see Make View Precise
or
do you see Make View Raster?
If that doesn't take care of the issue - can you post an image of your browser something like this?
It shows make view Raster.
I just realized that my drivers are not certified. I just downloaded the latest drivers from https://knowledge.autodesk.com/certified-graphics-hardware and installed them after a reboot the issues are now gone. The driver version I'm using is 419.17 file name is "419.17-quadro-desktop-notebook-win10-64bit-international-whql.exe"
