displaying last part of project name in 2D titleblock
I alreaddy worked (thanks to someone else) to get the full project name automaticaly to display in the titleblock of my drawings but I only need the part of it that is inbetween parentheses. Example:
Projectname full: BEKAERT - TER BEKE - WAREGEM (BBCTBW)
Projectfile: BEKAERT - TER BEKE - WAREGEM (BBCTBW).ipj
Projectname to display in titleblock: BBCTBW
Code I was given to get the projectname and copy it to my iProperties:
Dim IPJ as String
Dim IPJ_Name As String
Dim IPJ_Path As String
Dim FNamePos As Long
'set a reference to the FileLocations object.
IPJ = ThisApplication.FileLocations.FileLocationsFile
'get the location of the last backslash seperator
FNamePos = InStrRev(IPJ, "\", -1)
'get the project file name with the file extension
IPJ_Name = Right(IPJ, Len(IPJ) - FNamePos)
'get the project name (without extension)
IPJ_ShortName = Left(IPJ_Name, Len(IPJ_Name) - 4)
'get the path of the folder containing the project file
IPJ_Folder_Location = Left(IPJ, Len(IPJ) - Len(IPJ_Name))
'Converts the project file name to UPPER CASE
IPJ_Shortname = UCase(IPJ_Shortname)
iProperties.Value("Project", "Project") = IPJ_Shortname
iLogicVb.UpdateWhenDone = True
How can I isolate the data inbeween parentheses?
Thanks so mutch in advance!
Beli
drobbie
I updated your code a slight bit to search for the beginnning and ending parathesis and adjust the information that gets inserted to the Project Property field.
Dim IPJ As String
IPJ_ShortName = UCase(IPJ_ShortName)
'determine the location of the parethesis
IPJ_ShortName_Right = InStrRev(IPJ_ShortName, ")", -1)
IPJ_ShortName_Left = InStr(1, IPJ_ShortName, "(")
'Create the shorten version for use in the Titleblock
IPJ_Condensed = Mid(IPJ_ShortName, IPJ_ShortName_Left, IPJ_ShortName_Right - IPJ_ShortName_Left + 1)
iProperties.Value("Project", "Project") = IPJ_Condensed
Douglas Robbie
"When you focus on problems, you will have more problems. When you focus on possibilities, you'll have more opportunities." -- Harpreet Singh Batra
