Disable mini-toolbar sketch input
H2O__Water
H2O__Water
I upgraded tot 2025 and since tis release I see a mini-toolbar in sketch. Previously when I draw a rectangle I could directly input the length and width values and dimensions were added. In 2025 I get to see the mini-toolbar. How can I change this back? See images below.
2022 direct input2022 direct input2025 mini-toolbar2025 mini-toolbar
CCarreiras
Hi!
There's no difference here between version 2022 and 2025:
You probably activated the "Precise input" mode.
You have to exit the Precise input mode to have the standard mode again.
Check the video:
(view in My Videos)
CCarreiras
H2O__Water
Thank you that was the help I needed
