Assembly far from origin when placing into assembly
sales5N2FF
Message 1 of 16
sales5N2FF
I have assembly 1, and am placing it into assembly 2. When I go to home view of assembly 1, the whole assembly is in the frame, no issues. The assembly is grounded to the origin/origin planes.
When I place assembly 1 into assembly 2, the placement arrows (red green blue) are far away from assembly 1. When I do a home view, everything is zoomed very far out. Ive restarted the program and tried placing assembly 1 into a new assembly, and the same thing happens. I can't figure this out. Help? OriginDistance.jpg
Replies (15)
Message 2 of 16
gcooper79
In the application options, under the assembly tab, is the below option selected?
Graeme
Message 3 of 16
cnewmanVIK
Do you have any parts in assembly1 that are not visible that are far from the origin?
Message 4 of 16
sales5N2FF
Parts far away from origin: This was my first thought. I spent some time looking for far away parts, and making sure everything was visible. Couldn't find anything. When  I suppressed assembly 1 in assembly 2, the home view became appropriately sized. This suggested that something in assembly 1 is to blame. I opened assembly 1. The home view is appropriately sized. This tells me there is no far away part in assembly 1. Assembly 1 is grounded to origin, so I know it is at the origin.
Message 5 of 16
sales5N2FF
Thank you, that was not on. It doesn't solve the issue though.
I placed assembly 1 in a new assembly. It went to origin and looks okay. It is well aligned with the origin planes of the new assembly.  However, when I hit the home view (or zoom all), it still zooms very far out. If I place a second instance of assembly 1, it is far away from the red/blue/green arrow.
Message 6 of 16
sales5N2FF
Another thing I tried: I suppressed all the individual parts in assembly 1. Then I checked how assembly 2 was behaving. The zoom window is still far away, even with all individual parts suppressed. When I suppress assembly 1 completely, the view window returns to normal/expected.
Message 7 of 16
kacper.suchomski
A good way might be to build Ass1 from scratch (in a new file).
Kacper Suchomski
Message 8 of 16
sales5N2FF
Very much trying to avoid re-building it. That's the brute force solution which will be even BIGGER of a time sink than this troubleshooting, but it might end up being the only option.
I also want to know why this is happening so it can be avoided in the future. Huge time-suck this is.
Message 9 of 16
kacper.suchomski
Sorry, I can't read tea leaves.
I can't read anything and therefore identify the cause of the problem based on a dot on the screen.
Kacper Suchomski
Message 10 of 16
cnewmanVIK
In assembly 2, try turning off each individual part of assembly 1, one at a time, and after each one check the zoom.
Message 11 of 16
sales5N2FF
Kacper, your last response about "not reading tea leaves" is quite rude and unprofessional. It would suffice to say that without more detail you can't troubleshoot.
Please be courteous or remove yourself from being an "expert elite member" or replying on this forum. Or at least just stop responding.
Message 12 of 16
harvey3ELEA
I've seen this behavior when there's an oversized plane or axis not visible.  Just my 2 cents of input...
Message 13 of 16
sales5N2FF
Thanks for the suggestion! I had already done that and hit a dead end, BUT doing "find in window" for each was both much faster than the suppressing I had done, and the error was related to a part being flexible. I still don't really understand what exactly was going on, because I couldn't find any far away parts, but if it happens again there's a troubleshooting method that seemed to work.
Message 14 of 16
sales5N2FF
Thanks!
Message 15 of 16
johnsonshiue
Hi! Another way to bring it back to origin is to right-click on the instance in the browser -> iProperties -> Occurrence -> reset X, Y, Z offset values to 0.
Many thanks!
Software Test Engineer
Message 16 of 16
sales5N2FF
Thank you! I'll check this out if I run into this issue again.
