Is it possible to disable certain sub assemblies in a top level assembly from refreshing/updating?
A few people are working together on a project and work on specific sub assemblies only.
The guy that works on the top assembly constantly get warning about modification in the subassemblies - we want to disable those warnings/errors, and do an update ourselves when suited.
Many Thanks, Johan
Many Thanks, Johan
If you are on 2021 or earlier you can use level of detail to suppress them, but then you won't see them.
You could probably use model states to do this too.
I assume you aren't using vault or this wouldn't be a problem.
@johan.degreef wrote:Is it possible to disable certain sub assemblies in a top level assembly from refreshing/updating?
Many Thanks, Johan
Sounds like Vault is the solution.
Many Thanks, Johan
Vault copies all the files to your local drive. You get an icon to say a file has been updated, but it doesn't do it until you tell it to and there aren't any pop up messages whilst working.
It is however not as straight forward as just installing vault. It needs doing properly and people will need training on it.
Hi Johan,
I think indeed, this is what Vault is for. It helps you manage versions and who owns what at any given moment. Actually, the behaviors can be replicated without Vault. Let's say you have a data storage, which contains the latest and greatest. So, you make a copy of the entire assembly locally. Another user do the same. But, you guys work on different portion of the assembly.
After you are done, you guys can provide the files you changed back to the data storage. Kind of like a simplified manual Vault workflow.
However, it will only work if the two portions do not overlap. And, there isn't any dependency between the two portions. If there is any dependency, you will run in to confusing behaviors and failures fairly easily.
Many thanks!
Hi Johan,
Many thanks!
@johnsonshiue @SharkDesign @BDCollett
Oh sorry, this had to be on the Vault forum. We are using Vault Pro, but it seems that our user who is working in the top assembly, gets some update/refresh popups (or constrain issues) while other people are workin in/updating the sub assemblies. How can the user in the top assembly, set the subassemblies so they update on demand?
You shouldn't just get them randomly.
If you open a part from your assembly to edit on it's own and someone else has edited it you may get a message.
You shouldn't get constrain issues because they will be working with a local copy of the file so nothing will have been updated on their end. It's only if they choose to refresh the files from the vault add in.
