Hi @howardlee306 ,
You can disable sets of ribbon commands using a VBA macro
Public Sub Disable()
Dim oDoc As Document
Set oDoc = ThisApplication.ActiveDocument
' Disable Commands
oDoc.DisabledCommandTypes = 1
' Enable all Commands
' oDoc.DisabledCommandTypes = 0
End Sub
Here is a list of command groups that you could disable from the API Help File
kEditMaskCmdType 57
Commands that cause the document to become 'dirty'. Includes ShapeEdit, FilePropertyEdit, NonShapeEdit and UpdateWithReferences commands.
kFileOperationsCmdType 4
Commands that manage file operations - e.g. File Save.
kFilePropertyEditCmdType 8
Commands that edit File Properties (a.k.a Document Properties).
kNonShapeEditCmdType 32
Commands that edit data (other than File Properties) that is not directly related to the geometry of the model (e.g. color, style).
kQueryOnlyCmdType 2
Commands that purely query data. These do not 'dirty' the document.
kReferencesChangeCmdType 64
Commands that cause this document to change which files it references.
kSchemaChangeCmdType 128
Commands that change the format of the data, but do not change it otherwise (e.g. from the format of one Inventor release to another).
kShapeEditCmdType 1
Commands that can affect the geometry of the model.
kUpdateWithReferencesCmdType 16
Commands that cause this document to recalculate its contents with respect to changes that may have occurred in files it is referencing.
