Inventor Forum
Dimensions of a sheet metal part in an ipart
22 REPLIES 22
Message 1 of 23
gunter.stachon
2058 Views, 22 Replies
I would like to query the dimensions of an ipart so that the values can be read in Excel.
The ipart varies in dimensions.
22 REPLIES 22
Message 2 of 23
Welcome Gunter in our community!
I prepared for you short movie.
Please let me know is this help you to resolve your problem?
Damian Lewczyk
Technical Support Specialist
Message 3 of 23
Hello Damian
Thanks for the video. But that's not exactly what we were looking for.
We know how to create and edit iparts.
What we didn't find out is how to read the dimensions of the unfold (limits width (Y) and length (X) ) in it.
We use Inventor Prof 2019
Message 4 of 23
Hi! The workflow to do that is not that straight forward. The extent (width and length) of a flat pattern is more like a property of the sheet metal part, as opposed to driving dimensions or driving parameters.
iPart table is for driving parameters to determine how each member should behave. As a result, the extent cannot be be shown there. Even if you added them to the table, the values would be static. Here is what you need to do.
1) Open the iPart factory file.
2) Go to iProperties -> Custom -> create a custom text property called FLAT_WIDTH or anything you want -> set its value to "= <FLAT PATTERN WIDTH>". Then do the same for LENGTH accordingly.
3) Generate each member.
Now FLAT_WIDTH and FLAT_LENGTH will be added to each iPart member.
Many thanks!
Software Test Engineer
Message 5 of 23
Hi!
That's right, the workflow isn't straight forward.
We've tried what you suggested several times before.
But we always fail because the static values remain static. Also in the generated ipart this value does not change. At least not with Inventor 2019.
Why can't you just read this value (see screenshot)? It seems that this is a bug...
Message 6 of 23
Hi Gunter,
It should work. I did double-check before I replied. There could be an issue that I was not aware or the properties were not set correctly. Please share an example exhibiting the behavior here or send it to me directly (johnson.shiue@autodesk.com).
Many thanks!
Message 7 of 23
Dear Gunter
As @johnsonshiue  wrote, it is not possible to add any variable to iPart table, which is driven value. You can use there only dimension or value which control size, appearance etc.
iPart table does not include tool which query and check the value of driven dimension.
Damian Lewczyk
Message 8 of 23
Are you sure about this?
We use the Excel spreadsheets to control and also to retrieve data (resulting measures) which is then used on the drawing in the spreadsheets.
Message 9 of 23
Hi @gunter.stachon
I'm pretty sure you just need to add the custom iproperty(s) that is pulling the flat pattern extents, to the ipart table.
See this similar post where I described this process for another user, you would do the same but look under the Custom tab in the iProperties list and add the flat pattern iproperties that you created and included the formulas in (  =<FLAT PATTERN WIDTH> and =<FLAT PATTERN LENGTH> )
https://forums.autodesk.com/t5/inventor-forum/title-block-not-filling-in-iproperties-properly/m-p/90...
I hope this helps.
Curtis
Message 10 of 23
Dear @Curtis_Waguespack
I tried to use your idea, but it is one problem.
The values which you insert to StockNumber Column are dimension which controls some solid/sketch.
The values are not output which are calculated from the whole model using some function (in this case it is =<FLAT PATTERN WIDTH> and =<FLAT PATTERN LENGTH>)
If we want to use your method, we should know how the dimension which controls solid/sketch affects the flat pattern length and width. Using this knowledge we should create an equation and insert this equation to iPart Table.
Are you agree with me?
If I'm wrong or don't know something, please correct me.
@johnsonshiue  what do you this about this?
Damian Lewczyk
Message 11 of 23
Dear @gunter.stachon
The solution to your issue is only iLogic.
You can create Rule which will be checking Widht and Length and insert to iPart Table.
I suggest creating another post in INVENTOR CUSTOMIZE FORUM.
Kind Regards.
Damian Lewczyk
Message 12 of 23
Kind Regards.
@damian.lewczyk @gunter.stachon ,
Unless I am just misunderstanding, there is no need to use iLogic for this, I'll try an provide a more clear example later.
Message 13 of 23
Hi @damian.lewczyk
You seem to be confusing the goal of the other thread concerning Stock Number with this thread concerning flat pattern extents. I was in no way suggesting that using the stock number iproperty was part of the solution for this sheet metal question.
The stock number related question simply demonstrates the method to be used for getting the result in an iPart.
As I mentioned, I'll provide an example when I have some time.
I hope this helps.
Curtis
Message 14 of 23
Okay so I was mistaken on this... I apologize for any confusion I might have caused.
It's a shame that this is not built in to Inventor by now 😐 , but here is an ilogic solution that will make this work the way it SHOULD work.
Also, here is an Idea post for the is improvement idea:
Flat Pattern Extents for iParts
First create 2 columns in the iPart table using the Other tab
Then paste in this code
'ipart column names to use
oWidth = "FP_Width"
oLength = "FP_Length"
Dim oParent As iPartFactory
oParent = ThisDoc.Document.ComponentDefinition.iPartFactory
Dim oRow As iPartTableRow
Dim oColumn As iPartTableColumn
Dim oCell As iPartTableCell
Dim i As Long
'look at each row in the ipart table
For i = 1 To oParent.TableRows.Count
	'set the member for that row active so we can get the extents
	iPart.ChangeRow("", oParent.TableRows.Item(i).MemberName)
	'get extents values
	sExtents1 = SheetMetal.FlatExtentsWidth
	sExtents2 = SheetMetal.FlatExtentsLength
	'get the Cell
	oCell = oParent.TableRows.Item(i).Item(oWidth)
		'set the cell value
		oCell.Value = sExtents1
	'get the Cell
	oCell = oParent.TableRows.Item(i).Item(oLength)
		'set the cell value
		oCell.Value = sExtents2
Next
Then run the rule, and it will set the extents in each member row
I hope this helps.
Curtis
Message 15 of 23
Hi Guys,
Using iLogic rule with iPart/iAssembly is always tricky (too may 'I'). iPart/iAssembly should always be driven by the table. Any attempt to override the table using other means can be problematic.
For this case, you don't need to use iLogic rule, but it may not give you the formatting you like without iLogic (see attached simple sheet metal part). Activate each member and generate the member. You will see the iProperties are populated accordingly. However, the values are in internal unit "cm" as opposed to doc unit. In order to have meaningful formatting, you do need to use iLogic rule.
I don't think theses physical properties (flat pattern or mass prop) should be stored on the iPart/iAssembly table. It is because the physical properties are driven by the geometry, which is driven by the table. As I noted earlier, the table should always be the driver. iLogic sort of helps mitigate the situation by updating the table.
Like I said, this is not a trivial workflow. I don't think we have a good solution to this at the moment. It requires several workarounds just to make it work.
Many thanks!
Message 16 of 23
Hi @Curtis_Waguespack,
How can I export FP_Length & FP_Width so that I can include into BOM of assembly?
I would like to get the below result
many thanks
Message 17 of 23
johnsonshiue
in reply to: iLimbani
Hi! Are these iProperties in the iPart? You may need to edit iLogic rule and populate the two properties to custom iProperties.
Many thanks!
Message 18 of 23
iLimbani
in reply to: gunter.stachon
Hi @johnsonshiue. My Goal is to achieve entry for FP_Length & FP_Width in assembly BOM.  For that, I exported FP_Length & FP_Width using iLogic-1 (given below). It works perfectly, however, when I run @Curtis_Waguespack iLogic-2 gives error (COMMENTED). I am running his rule because I have added new line item in iPart member and I want to get values of FP_Length & FP_Width in iPart Table. Once we solve out this issue, we can have FP_Length & FP_Width values in assembly BOM
iLogic-1
Dim oPartDoc As Document
oPartDoc = ThisDoc.Document
If oPartDoc.DocumentType = kPartDocumentObject Then
    Dim oPartCompDef As PartComponentDefinition
    oPartCompDef = oPartDoc.ComponentDefinition
    Dim oParams As Parameters
    oParams = oPartCompDef.Parameters
    Dim oUserParams As UserParameters
    oUserParams = oParams.UserParameters
    Try
        Dim oFP_Width As Parameter
        oFP_Width = oUserParams.Item("FP_Width")
    Catch
        ' The user parameter "FP_Width" does not exist
        Dim extents_width As Double
        extents_width = SheetMetal.FlatExtentsWidth
        oUserParams.AddByExpression("FP_Width", extents_width, "mm")
    End Try
    Try
        Dim oFP_Length As Parameter
        oFP_Length = oUserParams.Item("FP_Length")
    Catch
        ' The user parameter "FP_Length" does not exist
        Dim extents_length As Double
        extents_length = SheetMetal.FlatExtentsLength
        oUserParams.AddByExpression("oFP_Length", extents_length, "mm")
    End Try
End If
Parameter.Param("FP_Height").ExposedAsProperty = True
Parameter.Param("FP_Length").ExposedAsProperty = True
Result of iLogic-1 (Working)
iLogic-2 (from @Curtis_Waguespack )
oWidth = "FP_Width"
Dim i As Long
	'get extents values
	'get the Cell
	oCell = oParent.TableRows.Item(i).Item(oWidth) '/// GETTING ERROR HERE
		'set the cell value
	'get the Cell
	oCell = oParent.TableRows.Item(i).Item(oLength) ''/// GETTING ERROR HERE
		'set the cell value
Next
Message 19 of 23
johnsonshiue
Hi! I took a quick look at the rule. I think the column name might be wrong. "FP_Width" and "FP_Length" should be custom iProperties. I believe the actual column names are "FP_Width [Custom]" and "FP_Length [Custom]" respectively.
Many thanks!
Message 20 of 23
iLimbani
Hi @johnsonshiue , defining column name in iPart Table as "FP_Width [Custom]" and "FP_Length [Custom]" is working only if we do following.
New Ilogic -2 will look like,
- Delete the User parameter defined using iLogic - 1
- iLogic - 2 (from previous post)
- iLogic -1 (from previous post
Thank you so much
