dimension to an intersection
Message 1 of 13
Trying to dimension to an intersection across 2 radii. Why is this so difficult., When applying given instructions ie using normal procedures its still not simple or working. Please see attached sketch.
Replies (12)
Message 2 of 13
SBix26
I would probably place the dimension to nearby points, then drag each end to its intersection point, carefully swiping along the two intersecting lines on your way.  You will see a yellow dot and dotted extensions when you get to the intersection.
If you can post an example drawing (and model), I'll try to create a video for you.
Sam B
Inventor Pro 2019.3 | Windows 7 SP1
LinkedIn
Message 3 of 13
blandb
Hope the attached helps:
Start dim > Select "1" line in the pic > Right-click > "Intersection" > select "2" in image. Next, Click "3" in image > Right-click > "intersection" > Select "4" and place the dim. This will create the intersection marks.
Autodesk Certified Professional
Message 4 of 13
johnsonshiue
Hi! Like Brad and Sam mentioned, it is not hard to do. You can find quite a few instruction materials online showing the exact workflow. Here is a video.
https://www.youtube.com/watch?v=sV-x4kZ5ymE
Or, you simply google the phrase "autodesk inventor intersection dimension" or "autodesk inventor virtual round dimension."
Many thanks!
Software Test Engineer
Message 5 of 13
Thanks Johnsonshiue
I agree it seems simple to dimension an intersection ,please my attachment ,the problem seems to be creating an intersection dimension to two intersections. In my sketch I require a dimension as such that it is from intersection to intersection not from intersection to centre line, this would make dimension 1.982 to 3.964.
In AutoCAD its a simple case of picking all four line and placing the dim.
Any suggestions would be appreciated.
Message 6 of 13
JDMather
@Anonymous wrote:
... In my sketch I require a dimension as such that it is from intersection to intersection not from intersection to centre line, this would make dimension 1.982 to 3.964..
This is easy to do in Inventor once you understand the technique.
The first time around can be confusing.
Edit:
Are these two edges lines, or are they actually large radius arcs or splines?
(This can easily be checked by attempting to add an Angle dimension. If angle is accepted, then they are lines.)
Can you Attach the *.ipt file here?
Message 7 of 13
Thank you JD
I have worked around the problem by attaching a pcd line central to the trigonometry , this then enables me to dimension to an intersection and then to the pcd line, its adequate for manufacturing purposes.
Regards
Message 8 of 13
mark.martinezECRPT
For some reason this does not work in Inventor 2023 now.
Message 9 of 13
SBix26
Both techniques mentioned in this topic work just fine in Inventor 2023.2, anyway.  Can you post images of the problem?  Can you post the model and the drawing?
Sam B
Inventor Pro 2023.2 | Windows 10 Home 21H2
Message 10 of 13
johnsonshiue
Hi Mark,
This was a known issue in 2023.0. It has been fixed in 2023.1 or 2023.2. Please install 2023.0.1 (a style related fix requires this to be installed first) followed by 2023.2 update.
Many thanks!
Message 11 of 13
damian.mazurekKJYGW
Is it possible to add to the intersection point of a line and the tangent to a radius? If not is it possible to add this option?
Message 12 of 13
kacper.suchomski
You can sketch it and then dimension it.
Kacper Suchomski
Message 13 of 13
SBix26
Vote for this idea: Drawings - Dimension to Apparent Intersections With Arcs
It's only 11 years old!
Sam B
Inventor Pro 2026.1.1 | Windows 11 Home 24H2
