Inventor Forum
dimension of angle
4 REPLIES 4
h.hartwig
585 Views, 4 Replies
dimension of angle
Hallo, i have this angle you can see in the picture, i will still have the 3.69 but on other side so it not in the part but when i move it its change, anny tips to do this?
4 REPLIES 4
mcgyvr
in reply to: h.hartwig
I'm not able to understand the question
Are you saying that the dimension is changing from 3,69 to 3,7 when you move the dimension?
Or are you saying that you want to move the dimension so the text does not overlap on the dimension extension lines?
Maybe a picture showing "before" you move it and "after" you move it would be helpful.
and "Angel" is a spiritual creature and "Angle" is the relationship between 2 lines.
Its also "Hello" not "Hallo"...
h.hartwig
in reply to: mcgyvr
Hi and thnaks for fast respons
I mean i have this dimension an try to move it, so it not overlap but wen i move the dimension its change to 176,3
How can i keep 3,69 but have outside the dimension lines?
I hope this explain my issue?
Best regards
Heinrich
andrewiv
I think you are trying to keep the dimension the way that it is but move the text so that it doesn't overlap the part.  The way I would do this is go into the Styles Editor and change the text location of angle dimensions.  Right now it looks like you have it set to Parallel-Aligned, change it to Inline-Aligned and if the text doesn't fit in-between the extension lines it will automatically move to the outside.
Andrew In’t Veld
Designer / CAD Administrator
h.hartwig
I have fixit, i deactivated use quadrant
