Dimension Equation not equal to nominal
mcgyvr
Consultant Consultant
mcgyvr
Coworker was using the offset command..
#1-The offset went the wrong direction (they clearly had the preview pulled larger than the source lines but the offset went in)
BUT
#2-He entered .015 for the dimension and it somehow goes to .009 nominal?
How could that happen? I can/will get a screencast
Part attached 2020
Curtis_Waguespack
Hi @mcgyvr ,
Does he have the Snap setting on in the sketch environment? (check the little horseshoe magnet button)
I think this is the behavior that having snap on during the offset causes... you might recall a few postings about that issue on here in the past, maybe something to rule out at least.
offset issue:
https://forums.autodesk.com/t5/inventor-forum/offset-bug-in-inventor-2017/m-p/7494155#M665525
I hope this helps.
Curtis
mcgyvr
@Curtis_Waguespack wrote:
Hi @mcgyvr ,
Does he/she have the Snap setting on in the sketch environment? (check the little horseshoe magnet button)
I hope this helps.
Curtis
BINGO!!!
Snap to grid was ON..
A super duper cookie for you.. 🍪 🤗
