DIMENSION DISPLAY INVENTOR 2022
AnthonyHarris90842
Message 1 of 89
AnthonyHarris90842
I am working in a part file and even though I have set my template file to display dimensions as expressions and again changed it in document properties it keeps reverting back to just displaying the dimensions. The setting shows Dimension as expression.
I change this a number of times during my session.
Replies (88)
Message 2 of 89
johnsonshiue
Hi Anthony,
If the change has been saved in the template, it should work. Are you able to reproduce it persistently?
Many thanks!
Software Test Engineer
Message 3 of 89
AnthonyHarris90842
Yes its happened a few times yesterday and I checked the template file and in the file I was working on.
Also as you noticed in the image I attached the setting is on expression but the dimension is on value
Message 4 of 89
matt.munn98SBR
We have the same issue, it keeps reverting to "Display precise value".
Is there a patch for this yet?
Message 5 of 89
johnsonshiue
Hi Anthony and Matt,
I am on an internal build targeting 2022.1 update. I cannot seem to reproduce the behavior. It may have been fixed. A testable patch targeting 2022.1 is available on Inventor Feedback Community (https://autode.sk/InventorBeta). Please take a look and try it out.
Many thanks!
Message 6 of 89
matt.munn98SBR
I can't see any patch downloads in there?
Message 7 of 89
SBix26
Inventor 2022.1 Beta is what @johnsonshiue is referring to.
Sam B
Inventor Pro 2022.0.1 | Windows 10 Home 20H2
LinkedIn
Message 8 of 89
TheCADWhisperer
Can you Attach a file that exhibits this  behavior where the display doesn’t match the setting (delete any proprietary geometry).
Message 9 of 89
matt.munn98SBR
It happens on all ipt files. You can change it over but it then changes back 10-20 mins later.
Message 10 of 89
matt.munn98SBR
Is there any update on this?
Message 11 of 89
matt.munn98SBR
Assuming the next update fixes this when is it expected to be released?
Message 12 of 89
johnsonshiue
Hi Matt,
2022.1 is scheduled to be released some time in July (very soon). It is undergoing the last phase of validation before setting live. But, I am not entirely sure if the update will fix the issue or it was me not following the correct steps to reproduce it.
Many thanks!
Message 13 of 89
matt.munn98SBR
This issue is still present in release 2022.1.1
How do I get this escalated so it can be fixed?
Message 14 of 89
johnsonshiue
I am sorry I am still having trouble reproducing the behavior. If you know how to reproduce it persistently or it happens on a particular file constantly, please let me know.
Many thanks!
Message 15 of 89
matt.munn98SBR
It happens on every part file we create, the dimension display keeps reverting to showing the value even though the expression is selected.
We have 3 Inventor 2022 stations here and they all do the same too.
Matt
Message 16 of 89
JDMather
Can you Attach a *.ipt file that exhibits this behavior?
Message 17 of 89
AnthonyHarris90842
Even with all the latest updates it still happens to my part files.
I dont think Autodesk has addressed this issue
Message 18 of 89
johnsonshiue
Hi Anthony,
As you can see in the thread, we are having problems reproducing the behavior. As a result, there is no fix. Would you be able to share a screencast and a part that exhibits the behavior?
Many thanks!
Message 19 of 89
matt.munn98SBR
Any update on when this is going to be fixed?
Message 20 of 89
JDMather
Can you Attach a *.ipt file here that exhibits this behavior?
