Dimension breaks when text is near
eedmondsHRMXH
eedmondsHRMXH
As per attached video, is there any way to overcome this?
I don't have space to just move the dimension, so it doesn't interfere with the text box break.
When I do the workaround of moving the text, adjusting the dimension, then putting the text back, it sometimes randomly breaks again.
Is there a permanent fix?
johnsonshiue
Hi! This was implemented a few years ago as a means to avoid dimension lines and text object collision. I am not aware of an option to disable it. You will need to move the text object elsewhere no dimension lines collide with the text.
Many thanks!
Software Test Engineer
alex_xuCAU9F
If it really bothering you, you can make text as a sketch symbol
See video attached.
