Dimbreak in inventor 2d
This widget could not be displayed.
Hi.
While I draw 2D idw file I put surface roughnesses x,y,z.
And they sometimes overlap with dimension lines.
Can't I dimbreak them like I do in Autocad?
Thanks.
mcgyvr
No that is not supported in Inventor.. Dimensions will break automatically when going over other dimensions but leaders like you have with your surface roughness indication will not.
johnsonshiue
Hi! This may not be related but I like to bring up in case you need it. There is a setting controlling if dimension value or text is clipped by Hatch. Go to Tools -> Doc Settings -> Drawing -> check "Cross Hatch Clipping."
Many thanks!
Software Test Engineer
lena.talkhina
Hello @Anonymous  !
Great to see you here on Inventor Forum.
Did you find a solution?
If yes, please click on the "Accept as Solution" button as then also other community users can easily find and benefit from the information.
If not please don't hesitate to give an update here in your topic so all members know what ́s the progression on your question is and what might be helpful to achieve what you ́re looking for. 🙂
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
