Difficulties to constraint 2 objects
Hey people, I'm trying to obtain the stress analysis of a bolt pushed on an object, for that I need to constraint the tip of the bolt with the middle face of the second object. I haven't been able to do it and I was wondering if someone could help me on that, thank you in advance.
mcgyvr
Just like in your last post...
What are the real life constraints on the object?
Whats fixed/Whats not,etc...
With FEA... Garbage In = Garbage Out
If the bolt head is fixed axially then the bolt shaft will deflect.. If its not then the whole bolt will just slide over
FEA is a great tool... For those that are aware of how to use it properly.. Its not a beginner tool..
If not done right its just a pretty/colorful picture with no real meaning/incorrect results.
Don't forget you can constrain to part origin planes too..
And pictures are great.. but post the parts too..
Thank you for your answer, I am aware that those tools aren't for beginners but I don't have the choice on the method to use to conclude this research so I am doing my best, the difference here is that I haven't used a chamfer with a hole but only a plane face which seems to me to simplify a lot the design. The base part is fixed and the goal is to have it slide, I have multiple designs with different bases, the goal is to study the stress analysis for each. I give you the assembly and different parts in attachments.
