I got there in the end but it has taken many steps. It is a difficult part. Could this part be made with less steps?.......Sam (Autodesk Inventor 2015)
Solved by WHolzwarth. Go to Solution.
Hi!
If you start again this part maybe you will do it with a few less steps, but overall you will have to do almost the same. In my opinion, that's well modeled, regardless if you can do it with more or less a couple of features.
Hmm. I stumbled about the 1st loft. Why are there different shapes between rail and edge curves?
Walter
Walter Holzwarth
Good question. How should i improve the part so it is correct?
How would you then make this part?
Can you post your attempt please?
Here's only the startup feature. Please ask for more, if needed.
Walter Holzwarth
Here's the whole part, but only minor changes.
Walter Holzwarth
