Inventor Forum
Desing Accelerator
1 REPLY 1
Jose_Merino
205 Views, 1 Reply
Desing Accelerator
Good Afternoon, I'm star using Invetor 2022, I use to work with Inventor 2020, the think is in the inventor 2020, when i use the tool bolted connections it give me just one piece with the name bolted connections, and in my project folder it mades a folder name Dessing Accelerator, and i like that, but now with inventor 2022, it give me all the pieces that my bolted connections needs and all the times the I need to use the same bolted connections, crowding a lot my assembly tree, any body know how can I make this tool works similar that the one in inventor 2020?
Thank You.
1 REPLY 1
johnsonshiue
in reply to: Jose_Merino
Hi Jose,
Yes, it is still available. In the Bolted Connection dialog, find the "Enable/Disable subassembly structure" button at the top to the right. Press it once. It will persist as last used.
Many thanks!
Software Test Engineer
