I am looking to build a design table for Assemblies created in Inventor, so that whenever require a minor change in a particular part/assembly, it should be readily made available from the table and need not have to make changes part by part which is time consuming.
Solved by CCarreiras. Go to Solution.
Hi!
You can explore the concept of a parametric model:
Files attached (Inv23)
