Inventor Forum
DESIGN SPIRAL BEVEL GEARS - KLINGELNBERG ?
2 REPLIES 2
4236 Views, 2 Replies
I need help,
I'm trying to draw a spiral bevel gears sytem KLINGELNBERG , but the results do not match the actual measurements of the piece.
ex. measure of the real outside diameter of the gear = 356mm
DATA :
number of teeth pinion  = 9
number of teeth gear = 44
module = 5
shaft angle = 90 °
face width = 59mm
helix angle = 35 °
pressure angle = 20 °
Where am I wrong?
Tanks,
2 REPLIES 2
When personal mechanic from Autodesk.
Autodesk Inventor models this type of spiral bevel gears as below?
Thank you.
watch what you need to draw, height and width of the tooth steadfast
