Design Assistant
Design Assistant
arthurDTEYK
Design Assistant
arthurDTEYK
Design Assistant: Can I rename a part linked to drawing, that is already in an assembly?
CCarreiras
Hi!
Yes.
CCarreiras
johnsonshiue
Hi! It depends on how the link is established. If the part is consumed by the drawing and also consumed by an assembly (not referenced in the drawing), the best thing to do is to create a drawing view of the assembly in the same drawing. Then do the rename task on the drawing using Design Assistant. Otherwise, you will need to rename it twice and likely the assembly may prompt to resolve before renaming.
Many thanks!
Software Test Engineer
