Design Assistant - Renaming Files
the Rename in the action box is in GREY and cannot be selected for a part for which I want to change the name..
how come?
thanks
MikeKovacik4928
See attached PDF with steps of how to change the name of a part using design assistant
Regards
Michael Kovacik
2d & 3d Autocad and Inventor designer/draughtsman
Draughting/Designing (Manufacturing) (31 yrs)
-Drawing Board (3 yrs)
--Cad (28 yrs)
---Cadkey (4 yrs)
---AutoCAD 2d & 3d (16 yrs)
---Inventor (4 yrs)
---Autocad and Inventor Simultaneously (4 years)
---(and recently Autocad/Inventor Customisation)
Autodesk Product Design Suite Ultimate 2018
Autocad 2018, Inventor Pro 2018
(personal licensed copy)
Johannesburg, South Africa
(Impossible only means you haven't
found the solution yet)
You have to open the assembly where the file is used
 can't manage (rename) the partnumber
inventor asks to open it., Although the file is open, .. it keeps asking to open the file.
PaulMunford
Please post a screenshot showing the entire design assistant interface...
Customer Adoption Specialist: Autodesk Informed Design
Help | Learn | Forum | Blog | Ideas | Sample content | Linkedin
It only works for the 'PARENT WORKSPACE' File location. So all the parts from the assembly can be renamed, but I can't rename the assembly itself.
If I want to rename the assembly, I need to put it in another assembly (in that way the new assembly = root and the nested assembly = Parent)
Is it possible to skip this step and just rename the assembly from the first time?
jtylerbc
If I'm understanding that correctly, then that is perfectly normal.  You can't rename the file you actually ran Design Assistant from - regardless of whether it's a part, assembly, or drawing.
If the assembly is used in a drawing or as a subassembly in a higher-level drawing, run Design Assistant on that to rename your assembly.  If not, then just rename it in Windows.  The purpose of Design Assistant is to be able to rename the files without breaking links between dependent Inventor files - if there are no dependent links to other files in the first place, then you can just rename it manually.
