- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I should have posted this before I went further than I did.
But, I can be stubborn and foolish. Perhaps all here can learn from my folly.
I've spent a good deal of time building a multi-body part for fabrication.
As this is my first go through the process I wasn't too careful about naming parts before I made components into a separate assembly. All is well and good until I need to produce a BOM for production.
No sweat, a little research led me to the design assistant for renaming parts.
I made a critical error in this process.
I renamed my foundational multibody part in the Design Assistant dialogue window.
I thought, surely this out of the box designed feature would not let me do this if I were about to cause a serious issue; SURELY, it will throw a warning my way. SURELY.
No, it did not protect me from my own foolhardiness.
So, now when I open the renamed multi-body part. IT throws an error, as if IT is looking for the original file name it once had. It acts as though it is an assembly part with a missing link. But, it is just looking for a name it once had. I can no longer make components from this rather large multi-body part. Because, it cannot find itself to do so?
Does this make any sense to any of you brilliant and less foolhardy professionals?
If there is a way to heal this ipart, from it's apparent identity crisis, my appreciation would be akin to Pinocchio's father getting his second chance at fatherhood.
