Inventor Forum
Design Assistant Not Accessible (Greyed Out)
10 REPLIES 10
Message 1 of 11
willy_mullerHMURJ
427 Views, 10 Replies
Good day people,
I want to update my parts using Design Assistant. This can also include copying, replacing and maintaining files. However, all parts are being greyed out (see Figure 1) and I've  also got a migration warning for the assembled components (see Figure 2).
Figure 1: the greyed out parts, none of the parts can be clicked
Figure 2: migration warning for the related parts
A workaround or tips/tricks or helps regarding these issues would be much appreciated.
Willy Muller
10 REPLIES 10
Message 2 of 11
japike
in reply to: willy_mullerHMURJ
You'll need to migrate the files to the same version as Design Assistant.
Peace,
Jeff
Inventor 2024
Message 3 of 11
willy_mullerHMURJ
in reply to: japike
Hi Jeff,
Thank you for your answer!
Do you mean I have to migrate every single part manually? Or is there any workaround to it?
Message 4 of 11
3DAli
@willy_mullerHMURJ
Hi Willy,
you can use Autodesk Task Scheduler to automate the migration of multiple files and then use Design Assist
Best
Ali
Signature_Small
Message 5 of 11
This is only one assembly that contains less that 20 parts. But another assembly has more than 100 parts and these need to be updated as well. Is there any possible way to do this update rather quick and more efficient (hence not done manually) using tools within Autodesk Inventor itself. Thank you.
Message 6 of 11
willy_mullerHMURJ
in reply to: 3DAli
Hi Ali,
Thank you for your solution. I'd like to know if Vault is required to perform the Task Scheduler?
Willy Muller
Message 7 of 11
I use "Migrate-On-Demand"; option 2. from below (in other words, I never force a migration; but that's just me):
https://help.autodesk.com/view/INVNTOR/2024/ENU/?guid=GUID-BF6C7C26-F29E-4E4C-A18B-862EA4EEAD81
Message 8 of 11
Hi Mluterman,
Thank you for that solution. I'll try it out tomorrow and see whether it works with my circumstances or not (not having Vault).
Willy Muller
Message 9 of 11
3DAli
youre very welcome
No Vault is not required
Signature_Small
Message 10 of 11
3DAli
if you are using Vault, the best option is to use Graitec PowerPack for Vault and automate that process in the Vault,
let me know if you wanted to try it out 🙂
Signature_Small
Message 11 of 11
3DAli
in reply to: 3DAli
@willy_mullerHMURJ
there is also PowerPack for Inventor that allows you to automate this process per assembly for all its parts and sub-components
Signature_Small
