Design Assistant 2022 not showing linked files correctly
Jason_Murdoch
Jason_Murdoch
I am not able to batch update a skeleton file for an assembly as the design assistant is not showing the derived control part in all files that are using it, the design assistant will show the linked files in the Properties & Preview panels, but not in the Manage panel.
Inventor 2022.2  build 287
short video attached
johnsonshiue
Hi Jason,
The behavior does not look right to me. It could be Model States related. If possible, please share the files (zipped) that exhibit the behavior here or send it to me directly johnson.shiue@autodesk.com. I would like to understand the behavior better.
Many thanks!
Software Test Engineer
