Announcements
Design assisant location for a rename
berry.lejeune
berry.lejeune
Hi all,
I have to do a rename of a part in an assembly. When using design assistan, I select the part and rename it
But the destination folder always goes to the "workspace"
Is there somewhere a setting that I overlook that makes sure when I do a rename, that it just keeps in the folder where the original part is in.
When I do a copy it makes perfect sense that I have to select the correct folder for the new parts. But for a rename?
johnsonshiue
Hi! Design Assistant is Inventor Project aware. The default landing folder is \Workspace\. If not \Workspace\, what folder do you want to change it to? I guess you may want to Pack&Go the files, place them in a different folder, and then rename the files using Design Assistant accordingly.
Many thanks!
Software Test Engineer
berry.lejeune
The problem is that if I just do a rename from a single part. I'll have to search in my \Workspace for the correct folder (even though the renamed part will remain in the same folder as the original)
When I make a complete copy of a complete assembly I get it that you have to go in to the \Workspace to select/create a folder.
Can you even change the default folder where the parts will go?
johnsonshiue
Hi Berry,
Are you using Default project or a custom project? You may change the \Workspace\ in a custom project easily (move the files accordingly).
Many thanks!
