Hi @Cris-Ideas
My workflow usually goes something like this:
1. model a multi body skeleton part
2. Create parts (make components from skeleton)
3. Demote parts to separate sub assemblies if that's relevant. In this case I did it to _1 and _2 for the inner and outer layer of the vessel (based on whether it's in media contact or not)
4. Start filling instance properties on the TOP LEVEL assembly.
Now, what happened when the customer discovered they didn't want two identical ones, I went to my original assembly and did the following:
1. (top level assembly) Save Copy As -001 and -002
2. (top level assembly) double click on sub assembly to edit in place -> Save copy as _V1 and _V2 for both sub assemblies.
3. Opened top level assembly -001 and replaced the sub assemblies with the _V1 ones
4. Opened top level assembly -002 and replaced the sub assemblies with the _V2 ones
5. Went to the new sub assemblies 1_V1, 2_V1 and 1_V2, 2_V2 and constrained them differently to suit the new requirements
So no changes happened to parts involved in the design. Only the two sub assemblies, of which I have two versions, were changed.
Now, at the point of *save copy as* I had already started filling instance properties because I had already bought some materials that I kept track of (fortunately it was all from the same batch, so it wasn't a hurdle keeping track of), and of course those instance properties stayed as they should.
I would expect in this scenario for the assemblies -001 and -002 to separate entirely, and any instance properties entered into one shouldn't go to the other; however, that is not what I'm seeing.
In conclusion: I have two top level assemblies that reference two sub assemblies each, and those sub assemblies reference all the same parts, but the sub assemblies are constrained differently.
I was expecting to be able to have INDEPENDENT instance properties on each top level assembly, but it appears I am not.
_______________________________________________________________________________________
Intel Core i9-14900KF
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Inventor 2026 Professional
