Inventor Forum
Design Accelerator Splines
1 REPLY 1
375 Views, 1 Reply
Hi everyone,
I am working with Inventor 2012 to create splines between shaft and hub.  The shaft has a shoulder near the splines that is larger in OD than the splines.  Inventor is removing this shoulder when I place the splines.  I assume that it is due to tool clearance, but I am pretty sure Inventor is being too conservative with it.  I manually drew the tooling and I should have clearance to bring the splines closer to the shoulder than Inventor indicates.  Is there a way I can adjust this?
Thanks!
1 REPLY 1
KEJay74
On the settings page for the spline connector...change the "Radius" setting to a "real" value equalling your cutting tool diameter / 2.
