Inventor Forum
Design Accelerator, Adding Joint Material
1 REPLY 1
karthur1
199 Views, 1 Reply
I am using the Slotted Hub Joint Calculator. The material that I need for joint is not in the list. The first three columns are all labeled sigma (AL). When I hover over them, they all three say "Allowable pressure".
I take this is probably the ultimate tensile, yield and shear stress, but can someone confirm this?
The column headings should have the correct headings.
I went to the "Help" and it did not even mention the columns.
Kirk
1 REPLY 1
in reply to: karthur1
Check the Engineer's Handbook
Shaft Material (pressed on material)
pA [MPa]
static
repeated
alternating
Razvan Stancu
"karthur" wrote in message news:6004897@discussion.autodesk.com...
Kirk
