Inventor Forum
design a mechanism
2 REPLIES 2
mojtaba77f
340 Views, 2 Replies
design a mechanism
I wanna design this belt... But I don't know how can i do it?
Anyone can help me? Can Inventor design it?
I'm using Autodesk Inventor Professional 2017.
Cheers,
Mojtaba
2 REPLIES 2
Binga
in reply to: mojtaba77f
You will need to use adaptativity or code your design. But I think it is possible.
Gilberto Binga
Engenheiro Mecânico - Engenheiro Mecatrônico
deLearning - YouTube Channel
Facebook | LinkedIn
LOUCO POR AUTODESK
A resposta resolve seu problema? Ajude outros usuários marcando "Aceitar como Solução"
Does the answer solve your problem? Help others checking "Accept as Solution"
Curtidas são apreciadas caso tenha gostado da informação
Likes are appreciated if you liked the information.
I_Forge_KC
If you create the "rubber band" in the assembly environment and then project geometry it automatically becomes adaptive.
K. Cornett
Generative Design Consultant / Trainer
