Hi! Without seeing the actual file, I guess this is related to the fact that the derive source objects were not marked as Exported. Back in the very old days, Inventor used to make all derivable objects (solids, surfaces, sketches, parameters, and work geometry) from the source available for the user to choose. However, the performance of such operation is not good particularly the source part or assembly is big. In order to speed up the process, the scope of derivable objects are reduced. Only the objects marked as "Exported" are listed in Derive dialog by default. Also, by default, none of the objects are made "Exported."
When you derive an object, either it is already set to "Exported" or it is made "Exported" within Derive dialog. In your case, I assume the solid was not made "Exported" but Derive dialog made it for you when you selected. As a result, the source document is dirtied and it has to be saved. To check the status, go to the source document and go to Manage -> Export Objects. You will see if a given object has been set to "Exported."
Many thanks!
Software Test Engineer
