Derived part not updating appearance/"Use color override from source component"
DRoam
Mentor Mentor
Message 1 of 21
DRoam
I have several derived parts that came from the same multi-body part. Each of the derives has "Use color override from source component" checked. I have not applied any appearance overrides to the derived geometry. I changed the appearance of several of the bodies in the source multi-body part, but the recipient derived parts are not updating with this change, even though "use override from source" is checked. If I edit the derive and then say "OK" without changing anything, the appearance then updates correctly. But I don't want to have to do this for every part.
Is there a way I can force an "appearance refresh" so I don't have to do this for every part one by one?
I already tried a Rebuild All and that had no effect.
Thanks for any suggestions.
Replies (20)
Message 21 of 21
johnsonshiue
Hi Folks,
Please share an example that exhibits the behavior. It is either a bug or a limitation. I would like to understand the Derive coloring behavior better.
Many thanks!
Software Test Engineer
