- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have several derived parts that came from the same multi-body part. Each of the derives has "Use color override from source component" checked. I have not applied any appearance overrides to the derived geometry. I changed the appearance of several of the bodies in the source multi-body part, but the recipient derived parts are not updating with this change, even though "use override from source" is checked. If I edit the derive and then say "OK" without changing anything, the appearance then updates correctly. But I don't want to have to do this for every part.
Is there a way I can force an "appearance refresh" so I don't have to do this for every part one by one?
I already tried a Rebuild All and that had no effect.
Thanks for any suggestions.
