Derive/Simplify error
243204
243204
I get " SEAT.ipt: Errors occurred during update The Boolean operation failed when joining with Zadel_Turbo.ipt:" when running the derive or simplify command on the attached file.
I'm unsure of whats causing this, although the derive and simplify have worked fine for me in the past.
A.Acheson
Please attach . ipt and.iam in a zipped folder. If possible please attach error images.
Regards
Alan
Gabriel_Watson
Make sure the assembly is active and press Ctrl+F7 and you will see a diagnostics showing if something is wrong with the geometry (make sure you have a C:\Temp folder if the pop-up never comes).
Trying a Manage (tab) > Rebuild All has a slim chance of helping too, if you try again after that.
Also try to select the bodies in a different order to see if that helps.
"That can happen if you have surfaces that are nearly coincident, or where one surface intersects almost but not quite at an edge of the other surface. If you can post the part, I can have someone look at it to see if they can narrow down the problem."
https://forums.autodesk.com/t5/inventor-forum/error-while-deriving-assembly/td-p/2491383
