derive function malfunctioning
jessepranger
jessepranger
Greetings,
I got an STL file. I open the STL and save it as an IPT. I create a new ipt file and want to derive the saved ipt to mirror it. In the configution it works well and I can see the preview:
but I cant turn on any of the solid bodies:
so when I click on OK, it dissapears:
Any suggestions on what I can try to fix it?
kacper.suchomski
Hi
When you use the derived part, you see a dialog box allowing you to select the range of elements to be derived.
There are solids, surfaces, sketches, and parameters; there is no mesh.
STL file and geometry after import is mesh.
Kacper Suchomski
johnsonshiue
Hi! I suspect the object you are seeing is a mesh not a Brep body. Inventor does not support deriving a mesh. Inventor has very limited mesh handling workflow. I suggest you look into Fusion Mesh Design environment, which offers extensive mesh handling workflow. You may be able to convert the mesh to a smooth Brep body.
Many thanks!
Software Test Engineer
jessepranger
Ye thanks man, but like I said :" I cant turn on any of the solid bodies"
jessepranger
Like I said:" I cant turn on any of the solid bodies"
jessepranger
Thanks! I used a 3d printer slicer and exported it. Kinda sad how such an expensive piece of software is struggling with something any free slicing software can do easily
kacper.suchomski
You can include bodies. You can't include meshes.
The object you imported is a mesh.
Kacper Suchomski
