Hey,
I would like to get your suggestions on how to make the process that I do more efficiently. I have a part X and I have to make part Y that is a mirror of X except one feature - the length of the Contour Flange (the length of the sheet metal). When I do Derive, I got the mirror part but cant change the length without touching part X. I use the Derive because it enable me to do the mirror in a simple way. To bypass it I copy part X to another file, change its length, save it as part X1 and then derive part Y according to part X1.
I wonder if there is a simple way to do what I want, for instace a way to derive a part with mirror and then edit this part without touching the base part. Or maybe a way to use parameter to this length, and be able to change it for the derive. I really dont know, but hope this problem would raise some ideas that I could learn from.
Thank you.
Solved by kacper.suchomski. Go to Solution.
@mmatanlevi wrote:
...a way to derive a part with mirror and then edit this part without touching the base part.
Direct Edit or follow-on history edit of the Derived part.
Attach your file(s) here and indicate desired edit if you can't figure it out.
The base parameters cannot be edited in a derived part.
Apart from that, the whole moodeling process is exactly the same.
Kacper Suchomski
I thought about the Direct Edit option but someone told me its not a recommended method. I tried it on the part but didnt managed. I attached the part, maybe you could tell me how to do the Direct edit for it. The new part should be longer in 500 mm ("Countor Flange1"). Other than that, the Rectangular Pattern should be preserve (and add holes because of the stretch) and the oval slot should move also with the stretch so it would stay in the center of the face.
Thank you very much.
@kacper.suchomski wrote:Apart from that, the whole moodeling process is exactly the same.
what do you mean?
@mmatanlevi wrote:I thought about the Direct Edit option but someone told me its not a recommended method. I tried it on the part but didnt managed. I attached the part, maybe you could tell me how to do the Direct edit for it. The new part should be longer in 500 mm ("Countor Flange1"). Other than that, the Rectangular Pattern should be preserve (and add holes because of the stretch) and the oval slot should move also with the stretch so it would stay in the center of the face.
Sketch (on paper) what you want to achieve, because your ois can be understood in many ways.
Kacper Suchomski
Kacper Suchomski
https://help.autodesk.com/view/INVNTOR/2024/ENU/?guid=GUID-8E771DBE-1107-4AE8-BE3E-AF3A7977F3C6
Kacper Suchomski
You can derive them.
Kacper Suchomski
