Inventor Forum
Dell XPS 15 vs Razer Blade 15 for 2019 Inventor
11 REPLIES 11
Message 1 of 12
2576 Views, 11 Replies
Hi there, I'm buying a new ultrabook and will be using Autodesk Inventor 2019 on it. I was wondering whether anybody had expierience with the Dell XPS 15 and the Razer Blade 15, and know which one would be better for Autodesk Inventor alone.
Metrics
Dell XPS 15
Razer Blade 15
Full Name
Dell XPS15 9570 Razer Blade 15
Specification
i7 - 8750H Hexa Core
GTX 1050 Ti Max—Q
1080p, 60Hz
Killer Wireless 1535
2.01kg
357 x 235 x 16.8mm
GTX 1060 Max—Q
1080p,
Intel Wireless AC 9260
2.07kg
355 x 235 x 17.3mm
The XPS15 has a GTX 1050 Ti Max Q and the Razer Blade a GTX 1060 Max Q however the thermal solutions on each laptop are different. Is there a URL with benchmarks specifically for Inventor for laptops/ultrabooks online that I could check for the XPS 15 and Blade. Does anybody know the benchmark figures for these laptops specifcally for Inventor?
Metrics
Dell XPS 15
Razer Blade 15
Full Name
Specification
GTX 1050 Ti Max—Q
1080p, 60Hz
2.01kg
357 x 235 x 16.8mm
GTX 1060 Max—Q
1080p,
2.07kg
355 x 235 x 17.3mm
11 REPLIES 11
Message 2 of 12
mcgyvr
mcgyvr
RAM in each?
RAM in each?
Message 3 of 12
in reply to: mcgyvr
16GB in each 512Gb hard drive
Message 4 of 12
mcgyvr
mcgyvr
Assuming that the Razer its more expensive the XPS is likely a better deal and the performance difference is minimal if that for Inventor.
Not knowing the prices you have found I would likely go with the XPS..
Message 5 of 12
in reply to: mcgyvr
Thanks for your fast reply!
1. Does Inventor support multi threading? Is there any advantage to the 6 core over 4 core CPU?
2. Does Inventor use the GPU, or just the VRAM on the GPU?
3. Does it use NVidia CUDA CORE?
4. Have you found a website where there are performance benchmarks specifically for Autodesk for various laptops. I have looked and cannot find any.
Message 6 of 12
mcgyvr
mcgyvr
https://forums.autodesk.com/t5/inventor-forum/buying-the-right-workstation-for-inventor-au-2018-clas...
Message 7 of 12
leowarren34
leowarren34
1. IV is mostly single threaded bus use multiple threads for rendering and aspects of drawing
2. CPU mostly, VRAM on the GPU is needed though so don't ignore it, minimum 4gb vram recommended 6-8
3. Unfortunately no.
4. Best benchmark is inventor bench see over at that thread
I'd recommend the xps as you with the blade you'll pay a considerable amount more for minimal gains.
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
Leo Warren
Message 8 of 12
johnsonshiue
johnsonshiue
Hi! Let me embed my reply to your reply.
[JS]: Yes, Inventor is partially multi-threaded. It is not fully multi-threaded. Here are the MT supported operations.
https://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcarticles/Support-for-multi-core-processors.html
[JS]: Inventor utilizes GPU but it does not use GPU programming.
[JS]: The same as #2.
[JS]: There is a tool available on Inventor App store. https://apps.autodesk.com/INVNTOR/en/Detail/Index?id=3667345248776204460&appLang=en&os=Win32_64
Many thanks!
Software Test Engineer
Many thanks!
Message 9 of 12
in reply to: leowarren34
Thanks very much for your reply! I think I'll go with the XPS 15 then! Would you suggest a better ultrabook than the XPS specfically for Inventor, or is the XPS the optimum at the moment?
Message 10 of 12
in reply to: johnsonshiue
Thanks very much for your help. I have a much better understanding of the software now!
Message 11 of 12
in reply to: mcgyvr
Thanks very much for that link. That video was brilliant and packed full of valuable information about workstation/laptop selection for Inventor!
Message 12 of 12
leowarren34
leowarren34
It will defitely do you well, depends how big you want to go, but for upto medium assemblies should be fine, you may want to add an SDD in the future...
Leo Warren
Leo Warren
