Deleting unattached centerlines on a drawing
AnthonyHarris90842
Message 1 of 18
AnthonyHarris90842
I have an open drawing and design doctor tells me I have unattached centerlines.
I then try and select all the unattached centerlines through design doctor and then the screen does a dance all over the place and then only deletes one centerline whereas in the previous version it deleted all.
See screencast link
https://autode.sk/3JejiLA
Replies (17)
Message 2 of 18
johnsonshiue
Hi! It does look like a behavioral change. If possible, please share the files here. It will help me reproduce and understand the issue better.
Many thanks!
Software Test Engineer
Message 3 of 18
AnthonyHarris90842
Hi Johnson
The file that I used has been fixed and I already deleted the unattached centerlines one by one.
You can recreate the same situation by modeling a part with a few holes then draw a section through the holes and then add automatic centerlines. Then go back to the model and delete those holes and you will have unattached centerlines
Message 4 of 18
AnthonyHarris90842
Hi Johnson
This problem is still showing up on drawings in Inventor.
I have attached the drawing so that you can test it yourself.
Message 5 of 18
johnsonshiue
Hi Anthony,
Do you still have the files before this happen? Do you know how to reproduce the sick annotations from scratch?
Many thanks!
Message 6 of 18
AnthonyHarris90842
I have attached the files in my previous reply
Message 7 of 18
johnsonshiue
Hi Anthony,
The drawing dimensions are already sick. Unfortunately, it is impossible to tell what triggered the sickness. It could be due to a change in the model geometry or the component definition. Or it is a bug. This is why I am asking for files before the dimensions became sick and also the steps to reproduce it.
Many thanks!
Message 8 of 18
AnthonyHarris90842
Hi Johnson
Its easy to reproduce.
Model a plate and add 3 holes in the plate.
make a drawing of the plate and add the center lines.
Go back to the model and delete the holes.
Go back to the drawing and you will then find unattached centerlines.
Message 9 of 18
johnsonshiue
Hi Anthony,
Many thanks for clarification! I guess you expect the center lines to be removed (not becoming sick), when the holes are gone, right? I believe this can be controlled by a document setting. Open the drawing and go to Tools -> Doc Settings -> Drawing -> Invalid Annotations -> uncheck "Highlight." Then those sick center lines will be gone.
Thanks again!
Message 10 of 18
AnthonyHarris90842
No. Look at the Screencast link in the original post and see when I try and delete multiple sick annotations.
Message 11 of 18
johnsonshiue
Hi Anthony,
I see the issue now. It is about the ability to delete multiple sick annotations in Design Doctor dialog. The behavior does look funky. And the annotations are not deleted. I will work with the project team to understand it better. In the meantime, please use Doc Settings to remove the sick annotations.
Many thanks!
Message 12 of 18
AnthonyHarris90842
Thank you very much.
Message 13 of 18
johnsonshiue
Hi Anthony,
The project team has confirmed this legacy issue and reported it as INVGEN-83144.
Many thanks!
Message 14 of 18
mluterman
I do this (in the meantime):
Step 1: Temporarily move the drawing view(s) to the side. The unattached centerlines will stay put, and you can delete multiples at once by windowing them (that should allow you to get most of them).
Step 2: Move the drawing view back where it was.
Step 3: If there are more unattached ones in Design Doctor, that are present and you can't see them, these will then have to be deleted one-by-one in Design Doctor.
Message 15 of 18
AnthonyHarris90842
That would work very well.
Message 16 of 18
EdvinTailwind
I just had this behavior on a drive shaft with 12 key slots (for sprockets), where the slots had to be remodeled. Consequently the drawing lost all center mark references for the slots (2x12). The "dancing" caused by Design Doctor was spontaneous "slow TV"... 😄 😴💤
@johnsonshiue Any news on this bug? I'm using INV 2025.3.2, but can't find any info on what @AnthonyHarris90842 originally used when this was reported.
Message 17 of 18
johnsonshiue
Hi Edvin,
I just check INVGEN-83144. The latest status shows it has been fixed on an internal build targeting the future release. I don't think there is a plan to port the fix backward. Please feel free to contact Autodesk Product Support to demand porting the fix backward.
Many thanks!
Message 18 of 18
johnsonshiue
Hi Miroslav,
The enhancement is strictly limited to the manual "Retrieve Model Annotations" command in the drawing. It is not expanded to the automatically retrieving model dimensions workflow. The reason is that if all model dimensions are retrieved automatically, the user will need to delete those duplicate dimensions wherever they are not desirable.
To retrieve a duplicate model dimension, the user needs to use "Retrieve Model Annotations" command explicitly.
Many thanks!
