- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I found something strange today and thought I'd ask if this is desired behaviour?
I occasionally use functions in dimensions "on the fly" while in a sketch, but I think I'll avoid them like the plague after finding this.
Steps:
1. Create a sketch with two dimensions and make one a function of the other.
2. Delete the "source" dimension.
3. Make a new "source" dimension and then change it.
Result:
The original dimension stays in the model as a parameter (even if I didn't intentionally create the parameter as a user parameter), but is effectively hard-coded and invisible.
I can see why this is, but on a more complicated sketch it's possible to accidentally end up with something undesirable and not know about it.
Suggestion:
Should Inventor at least prompt to say that I am deleting a dimension that is consumed by other dimensions?
Should the parameter list have these highlighted in red or something to make auditing easier?
Maybe "Purge unused" in the parameters list could highlight "floating" dimensions.
This is a very simple example to illustrate the point.
