Delete split face
Delete split face
Delete split face
Hi !!
recently i received a part from a customer, that i need to rework the shape.
And i have a surface that are splitted in three. I try to combine all of these into only one.
I tried to delete the face with Heal option, but i can only combine two surface in one.
How i can do it?
I give a exemple that i create for a better comprehension.
Thank you, Jeff
CCarreiras
Hi!
For your example attached;
Delete the face without "heal"
Make a surface wirh loft.
Stitch the loft + the primary faces, and you will get back the solid.
check video:
CCarreiras
CCarreiras
Thank you, its work!!
