10:08 AM
I can't figure out how to make a radial hole, which location is defined by a distance from the wall (see picture). On the picture, it can be seen that the hole is not radial to the cylindric flange. The only way I can manipulate the work plane is by changing the angle. The Work Plane is defined by the Y Axis and the XY Plane. Is there a smarter way to do this. This way I have to try out different angles until I get the desired distance, which definitely is not smart at all.
Thanks in advance!
