Default settings for new Projects
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
So when I first started using Inventor, I thought that new Projects would inherit the settings from my Default project (settings like Appearance Libraries, Material Libraries, and Folder Options). However, this isn't the case. So every time I create a new Project, I have to add our 3 custom Material libraries (which is time-consuming because we can't multi-select, so I have to navigate to the folder and select them one, then navigate to the folder again and select another, then navigate to the folder again and select the last one), and then remember to set our custom library as the Active one.
Is there any way that I can set the default Material libraries for new Projects so that I don't have to manually set them up every time?
