DEFAULT CHAMFER DIMENSION
Message 1 of 11
Any way to make this not say "chamfer" by default?
Just seems unnecessary
Replies (10)
Message 2 of 11
Mark.Lancaster
Access your drawing styles (Manage ribbon tab) and change it per this image
Mark Lancaster
Message 3 of 11
Marco.Takx
I think the text Chamfer is placed in your Style library.
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
Message 4 of 11
Thanks!!
Message 5 of 11
chris66
Besides that, it should CHAMFER, not Chamfer.  The lack of caps really gets my goat...
Message 6 of 11
I feel you.  Had it been in all caps, I probably would have left it.  In this day and age, however, I'm not sure all caps is still a valid standard.  I imagine it came about to make thing more legible when things were annotated by hand.
Message 7 of 11
SBix26
@chris66 The lack of caps can be easily changed in the Style Editor:
You can have your goat back...
Sam B
Inventor Professional 2016 R2 SP1
Vault Basic 2016
Windows 7 Enterprise 64-bit, SP1
Message 8 of 11
chris66
First thing I did was go through the our styles and change all of the default text....
Message 9 of 11
k14348
   Is it possible to do the same via Vba?
-karthikeyan M
Message 10 of 11
Borsht
Can anyone update this for Inventor 2019?  Again the CHAMFER verbiage comes up as Chamfer.
Inventor 2017
Message 11 of 11
chris66
You need to go into Manage - Styles Editor on your machine and edit the text as explained above.
