or see the latest FAQ 🙂 (ha I finally got Kent on another way to skin the
cat)
Sean Dotson, PE
http://www.sdotson.com
remove all #s from email
"Kent Keller" wrote in message
news:6239DD4DCE5C0FF9A3A9A3F09BC78CE0@in.WebX.maYIadrTaRb...
> Try this and see if it helps
> If you are comfortable editing the registry you can try this. If you
aren't familiar with
> editing the Registry I would advise against it.
> Start the Registry Editor and locate the following key:
HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersionX.X\Translators\
> SatTranslator
> Create a new DWORD entry named SaveACISVersion and enter a value of 2, 3,
4,
> 5, 6 or 7. The value you enter represents the ACIS version used when you
> export to the ACIS file format:
> For example, if you enter a value of 5, an ACIS version 5 file is created
> when you export to the ACIS file format.
> Kent
> Member of the Autodesk Discussion Forum Moderator Program
> "Kirk A." wrote in message
> news:75DF54EA78CC65B8D5C3E133F7F453D2@in.WebX.maYIadrTaRb...
> > When I put the .bmp file in the sketch, the file name is also shown
below
> > the image. How do I get this to not show?
