Inventor Forum
De extruding part of a model
3 REPLIES 3
287 Views, 3 Replies
I have a part of a model that I have made and I was wondering if there is a way of making the element of it sticking out to be able to go inwards without completley designing the model again?
Here is a picture of the model:
P.S i am using Inventor 2014
3 REPLIES 3
JDMather
Simply edit the Extrusion feature and change to Cut rather than Join.
Attach your *.ipt file here if you can't figure it out.
johnsonshiue
Hi! Like JD suggested, you can edit the feature and change the type of operation. Or, you can use Direct Edit -> Move -> select the face and drag it outward.
Thanks!
Software Test Engineer
Thanks for your help. using cut in extrude worked 🙂
