Datum Target Help
Datum Target Help
ToddPig
Datum Target Help
ToddPig
In Solidworks, I create 3 sketches on my model with each sketch defining the location of the Datum Targets.
1 sketch with 3 points, 1 sketch with 2 points (or lines), and a 1 sketch with one point (or line)
(The die caster also uses these sketches to create their fixture)
I am then able to use these sketches in my drawing views to layout my Datum Targets.
I'm looking for an equivalent process in Inventor.  Any recommendations or ideas would be appreciated.
Inventor 2018
(23+ years of Solidworks, 5+ years of fighting Inventor)
Autodesk Vault Pro 2018
iParts = iHeadache
johnsonshiue
Hi Todd,
I thought you could use "Get Model Sketches" command to include sketches in the part. Right-click on the part in the drawing browser-> Get Model Sketches. After that, you can annotate the sketches.
Many thanks!
Software Test Engineer
