- Mute
- Permalink
- Report
Hey all,
I am working on a barrel cam design and wanted to use the design accelerator. It is a 5th-order polynomial cylindrical cam. I input all the relevant information into the accelerator and it says that all of the calculations check out. When I click "okay" and generate the cam, the model generated is just a cylinder with no cam cut in it. If you go into the actual model details, the end surface sweep of the cam has an error on it, so the face of the cam isn't made.
I can't figure out why this is happening. I try altering the parameters just to see what will happen and no matter what my inputs are, I get the same error. If you could offer any insight into how to use the design accelerator correctly, or why this is happening, that would be great.
I have attached the 3D model and a snapshot of my issue in-case you need to see it.
Thanks in advance for the help!
Nicholas
